Skinning Buildings
Re: Skinning Buildings
Postby freakinacage » Tue Aug 04, 2015 4:11 pm
I'd go for the blue foam. Paint over with exterior wall paint which has a vinyl like finish and not only is tough as nuts, seals the foam. paint normally after that. Should take a kicking
Postby Skipp » Tue Aug 04, 2015 6:19 pm
I'm tempted by stone - as Ian has suggested - and at some point that's what I'll do.
However I'm about to embark on further ruins for my ancient & ruined city project, And I'm going to go for milliput again, just like last time - only this time it's not going to be a tower.
You mentioned 3 packs - I reckon you could do loads with that many packs, so long as you don't bulk out the cladding too much.
As a reminder - this is what I did last time:
Postby geronimo » Tue Aug 04, 2015 6:36 pm
Still wish you'd made that castable.... :froth:
geronimo
Postby Skipp » Tue Aug 04, 2015 8:37 pm
geronimo wrote:Still wish you'd made that castable.... :froth:
I could do another?
Postby geronimo » Tue Aug 04, 2015 10:28 pm
Chop chop....
geronimo
Postby Skipp » Tue Aug 04, 2015 10:47 pm
geronimo wrote:Chop chop....
:rofl:
Touché
Postby Klingsor » Wed Aug 05, 2015 10:04 pm
Nice tower.
The book is:
Making Rural Buildings For Model Railways
By David Weight
Crowood Press.
I like it a lot, the Das thing is only one of the methods used.
Klingsor
Postby WillieB » Thu Aug 06, 2015 9:13 am
A Chaotic Humphrey wrote:Right chaps, would appreciate some advice and comments before I embark upon a building project.
I am going to be making some buildings, using foamboard. Thing is, I want a stone-built finish which leads me to my question - what's best to skin the foam board with before scribing a stone effect on it?
I am fed up with using ready-mix pollyfilla type materials - it's too brittle and chips very easily. That's pretty much out.
Which leaves me with two options - either car body filler or milliput.
Any other thoughts or ideas?
If you mix Polyfilla with PVA glue (50/50%) and a little water you end up with a mixture that, when dried, could survive a nuclear explosion.
Problem it dries a lot more rapidly than straight Polyfilla (I use Porion). Working time about 15 mins.
Advantages : dip the surface with a small sponge for an adobe effect. Scribe in stones with a err.. scriber and press rough bark to the surfaces to simulate rough stones. Smooth with water.
Adheres to anything including fingers, beards, cats and clothing.
Won't chip. Ever.
Panic, chaos and disaster. My job here is done.
WillieB
Postby Etranger2 » Thu Aug 06, 2015 9:48 am
Add some paint in the appropriate stone colour to that mix and it doesn't matter if it does chip. I use something similar for basing.
Etranger2
Postby Norton C Wongpower » Fri Aug 07, 2015 8:07 pm
Das is the devil's arse gravy.
Users browsing this forum: No registered users and 3 guests
