Sculpting Tips - Q&A
Re: Sculpting Tips - Q&A
Postby spectacle » Wed Jun 26, 2013 2:19 pm
If you're worried about licking putty residue, you can spit in a bottle cap or similar and lubricate your tools from that.
spectacle
Postby Bergil » Wed Jun 26, 2013 3:40 pm
freakinacage wrote:Yeah any sebum works, forhead, nose and neck
Something wrong with you if your saliva eats rubber!! Like seriously wrong. Or you have shit tools
I'm walking into this, but such as?
Bergil
Location: I live in a country that isn't worth the cost.
Postby freakinacage » Sun Jul 07, 2013 3:44 pm
Fuck knows man, sounds like something from a space marine novel tbh! Saliva is mostly water and various enzymes, it really shouldn't eat it's way though rubber!
Postby Juuso » Tue Jul 16, 2013 7:22 am
I got this new set of silicone shaper tip thingies, are these good for sculpting? I am assuming they won't stick to putty either?
Juuso
Postby ink the troll » Tue Jul 16, 2013 8:52 am
If it's something like these things then yes, they're quite good for sculpting. I find that a bit of lubricating dosn't hurt, despite the putty (almost) not sticking to them.
sanity is for cowards
blogthingy
ink the troll
Postby Juuso » Tue Jul 16, 2013 9:04 am
Thanks, yes those are the ones.
Juuso
Postby Bergil » Tue Jul 16, 2013 3:22 pm
Juuso wrote:Thanks, yes those are the ones.
i use those for say 90% of the work I do. Just use a bit lube as Inky says.
Bergil
Postby Aquila » Tue Aug 20, 2013 6:23 pm
Doremi Fasol Latido wrote:What's the best way to make arrow flights in 28mm? I've tried bits of greenstuff but the shitting stuff just sticks to everything but the pin I'm using for the arrow (yeah yeah water...), is awkward to position and is getting on my tits. Paper will just look wanky I'm sure. Anything better or tips on how the pro's do it?
For casting or generally? If the latter this is a great article. I haven't really seen it done better, although you may want to vary proportions to keep in scale with differently delicate manufacturers.
http://massivevoodoo.blogspot.co.uk/201 ... rrows.html
Available for sculpting and painting commisions, PM me.
Aquila
Postby sjoerdo » Wed Aug 21, 2013 6:03 am
if for casting, add a big blob of green or grey stuff to the end of the shaft. let it settle completely and then carve/file out the flights. Only way i've managed to pull it off.
sjoerdo
Postby Klingsor » Sat Aug 24, 2013 7:43 pm
If I wanted to make my own stone wall to cast what is the best way to do it? I was looking at the (lovely) ones from Fenris and I am not even sure if they are sculpted or built up from separate pieces. I am fairly sure that anything involving glue and lots of bits of stone would end badly.
Klingsor
Users browsing this forum: No registered users and 7 guests
