Glueing fiddly fucking models...
Postby Skipp » Fri Aug 12, 2016 5:02 pm
I have some hasslewassle dwarves, which have seperate hands n weapons.
How in the world of fuck am I meant to put the hands on?
I tried pinning, but the wrists aren't big enough (for me)...
These will be gaming minis, so a toughness of joint important.
Any advice?
Re: Glueing fiddly fucking models...
Postby Monkeyborg » Fri Aug 12, 2016 5:05 pm
Two part epoxy glue, or a tiny blob of green or grey stuff and superglue, I'd say.
Monkeyborg
Postby Skipp » Fri Aug 12, 2016 5:07 pm
Was thinking araldite, but have found it hard to work with previously, it dries too fucking quick... But I suppose I should have a go..
Postby Monkeyborg » Fri Aug 12, 2016 5:12 pm
Epoxy glue is a bitch to handle, relying on quick clean up of the areas it contaminates, as soon as possible.
Perhaps someone else has a 'cleaner'/easier option?
Monkeyborg
Postby Inso » Fri Aug 12, 2016 5:39 pm
I use 0.8mm wire, drill and pin, glue with superglue.
Pinning is the only way to get a really secure joint.
Postby Duff » Sun Aug 14, 2016 12:04 pm
What Inso said. You need to use the really fine piano wire in small joins like those. Though you should find that even superglue will be pretty tough on flat connecting areas like those dwarves have iirc.
Postby tiacapan » Sun Aug 14, 2016 1:29 pm
I put together a bunch of them with superglue on its own, I just ri ought need the felt surfaces with a needle file first, still fiddly but they hold up to use quite well.
viewtopic.php?f=27&t=47031&p=922684#p922684
The voices in my head want me to hurt you...
tiacapan
Postby Skipp » Sun Aug 14, 2016 6:48 pm
Duff wrote:What Inso said. You need to use the really fine piano wire in small joins like those. Though you should find that even superglue will be pretty tough on flat connecting areas like those dwarves have iirc.
tbh, Im too cack handed for drilling - my eyesight isnt up to it...
I'll try superglue, had discounted it as I thought it wouldn't do the job...
Postby The Dozing Dragon » Sun Aug 14, 2016 7:54 pm
Superglue then maybe add a little milliput or similar around the joints if you're worried about handling probs?
The Dozing Dragon
Postby DemonEtrigan » Sun Aug 14, 2016 9:27 pm
Use the Gel superglue as hat will spread nicely and give a stronger bond.
DemonEtrigan
Users browsing this forum: Majestic-12 [Bot] and 31 guests
