Khurasan releases 20mm sci fi
Postby Khurasanminiatures » Wed Oct 09, 2019 4:03 am
We've just released the first set of our 20mm sci fi range, “Under Three Suns,” about a massive human effort to colonize a planet in the habitable zone in the tri-star system Alpha Centauri, which gets more than it bargains for, then MUCH more than it bargains for. The range can be seen here (it's just one code so far):
http://khurasanminiatures.tripod.com/20mmscifi.html
The first release is of the ColSec forces, very well equipped Colonial Security with armour and weapons brought from Earth. It's a set of seven poses. The models are made for 20mm scale gamers so are approximately 25mm head to sole.
After the colonisation is fiercely contested by the warlike natives, the colony has no choice but the press its youth into action, and the CYRs (Colonial Youth Regiments) are raised, boys 13-15 years old, with cheaper weapons and armour produced by the limited industrial capacity on the colonies as these hang on by the skin of their teeth. The CYRs will be released next, followed by Shunq tribal warriors, who are substantially taller than humans.
Khurasanminiatures
Re: Khurasan releases 20mm sci fi
Postby Guest » Wed Oct 09, 2019 5:04 am
After the rather hackneyed and half-arsed bit of background fluff, you forgot to mention that they also turned into a race of pinheads.
Users browsing this forum: No registered users and 4 guests
