Khurasan releases 15mm Ottoman Turks
Postby Khurasanminiatures » Thu May 03, 2018 4:35 pm
We've just released a range of Ottoman Turks for the 15th-17th centuries. The range contains cavalry, infantry, artillery and command. While it was made as part of our Late 16th Century range, for the "Long Turkish War" at the end of the 16th century, the conservatism of Ottoman dress and equipment means that the figures are perfectly suitable for at least one hundred years before and after. There are too many codes to show in this post so below are just two samples. Available now:
http://khurasanminiatures.tripod.com/ottoman.html
Janissary archers:
High command (first two figures are a sub-general and his standardbearer, the rest being the Sublime Porte -- standardbearer, provincial governor, the sultan, and his ic-oglan):
Khurasanminiatures
Re: Khurasan releases 15mm Ottoman Turks
Postby Bronshtein » Fri May 04, 2018 8:15 am
I never buy from people without a physical address listed.
Bronshtein
Postby sane max nl » Fri May 04, 2018 8:30 am
Khurasanminiatures wrote: While it was made as part of our Late 16th Century range, for the "Long Turkish War" at the end of the 16th century
You can't help yourself lying now can you 'John'. These were NO WAY made in the 16th Century.
sane max nl
Users browsing this forum: No registered users and 11 guests
